Tractor Talk Discussion Forum
1010 John Deere sleeve deck
Jerry K
01-03-2005 16:15:11
Where can I get a sleeve deck for a 1010 John Deere engine?
Roger W
01-04-2005 17:48:20
 Re: 1010 John Deere sleeve deck in reply to Jerry K, 01-03-2005 16:15:11
Jerry- E-mail me I have a good used deck in the shop. send phone # and I will call you. Located in NE
jdemaris
01-04-2005 05:51:43
Last I checked, Deere still sells them. If you're looking for used deck, keep in mind the diesel 1010 has a different bore than a gasser. The sleeve deck from a 2010 gas engine is the same bore as the 1010 diesel, and I believe, the same part number.
Mel SD
01-03-2005 20:37:06
I put a new one in my 1010 diesel two years ago. Got it from JD for around $450. The old one was cracked where the sleeve meets the deck. I wouldn't put a used one in without checking it close for cracks there.
Roger W
01-03-2005 18:39:24
Have one hanging on the wall of shop will have to clean if you are interested. If I rember it is in good shape. leave phone # if you want
rjb
01-03-2005 16:19:40
you might be able to get one a a scrap tractor yard. do you now were to find the serial num is for the 1010
