Tractor Talk Discussion Forum
Wal-Mart Oil
Davis D.
01-03-2005 18:24:51
Would anyone know you makes the super tech (wal-mart)brand oil. I mainly use Rotella in my tractors but have considered using the Wal-Mart store brand. Also, a NAPA store guy told me that the NAPA brand was valvoline. Any info on that? Just thought I would see if anyone might know. What a great site for learning about old tractors.
dej(JED)
01-05-2005 11:13:01
 Re: Wal-Mart Oil in reply to Davis D., 01-03-2005 18:24:51
I run an oil testing lab and we collect API oils every year, about 1000 - 4 qt. samples to be exact. The sample are then tested to see if suppliers are complying with what they say they are selling. Oils bearing the API logo seem to have very few off spec products, usually about 1 in every 100. The tech one is a good oil.
Jerry/MT
01-05-2005 17:40:34
 Re: Wal-Mart Oil in reply to dej(JED), 01-05-2005 11:13:01
It's good to hear the comments from those people that have hard data. Thanks for your reply.
IHC Red
01-05-2005 03:20:05
Someone said that Super Tech is recycled...
I use Mobil 1 in anything I care about.
FarmerDave
01-04-2005 18:42:57
Since my fellow Americans already sent my job to India, I don't worry about them any more. I been using super tech oil for a couple of years, as long as I been unemployed, seems to work about the same as the others.
I did think is was strange the price of gas went through the roof and the price of supertech held steady.
Jerry/MT
01-04-2005 15:39:02
If it meets the required SAE weight and the API service classification in your manual, it doesn't matter who makes it. It's not like the refineries make a bad batch to sell to Wal-Mart. It cost more to change over the refinery equipment to make poor qualitiy lube oils than you'll ever make selling to Wal-Mart. And then you have to keep it separate in storage and on and on. Lube oil is a comodity. They (Wal-mart) get a good deal because they buy in vast quantities. I don''t believe brand is important. I've had a Ford Service Manager tell me that he's seen more cars that had lube related failures that used Penzoil. I don't believe him but that's what he said.
I buy my oil at Costco. It's Chevron and they are cheaper than anyone else in my area and IT MEETS THE SAE WEIGHT REQUIREMENTS AND THE API SERVICE CLLASSIFICATION that the vehicle/tractor manufacturers specify.
JPatton
01-04-2005 16:23:32
 Re: Wal-Mart Oil in reply to Jerry/MT, 01-04-2005 15:39:02
I tend to agree with your mechanic on Penzoil. While it is true that all major brands meet the SAE ad API specs, some are naturally better than others. I have taken a lot of engines apart and if they are maintained as they should be then Penzoil is fine. What I have found is that neglected engines that run Penzoil are terribly dirty on the inside. A lot more that other oils. It has been a long time since my Fuels and Lube class in college but I remember seeing a report on oils ranked in order and Penzoil was the last entry on the report. Again, it met all the requirements but my feeling is that I can spend that $$$ on another brand of oil that ranks better for the same money.
Just my opinion.
Jerry/MT
01-04-2005 18:39:53
 Re: Wal-Mart Oil in reply to JPatton, 01-04-2005 16:23:32
Thanks for your response.
I guess the operative words are "...maintained as they should be...". To me that's per the manufacturer's instructions. I foumd that most people don't read the maintenance instructions and use the maximum allowable miles between changes as the bench mark. If you read(and it's not in fine print) the maintenance instructions for engine oil changes, a condition called "Severe Operation" is defined. It usually goes something like this: stop and go traffic, long periods of idling, dusty roads, operating for short periods of time daily, etc. If that's the case, then you should change the oil every 3000 miles or three months which ever comes sooner. It's hard for me to fault a brand because somebody went 40,000 miles before they changed the oil, yet we all know someone who thinks that way. Just my opinion.
dieselade
01-04-2005 15:18:41
If it wasn`t for walmart, I couldn`t buy a car tire/truck tire on sunday in my county. or have one repaired for that matter. I had a cut in my car tire on sunday,went flat. I had to be on the road monday at seven am.
sugar bear g
01-04-2005 13:25:52
how low our you willing to go with walmart.
Andy
01-04-2005 09:18:59
Check out this website. Lots of good info and testing results...
dhermesc
01-04-2005 11:10:22
 Re:Good Link in reply to Andy, 01-04-2005 09:18:59
Been wondering when somebody was going to start calling companies on their snake oil cure-alls for oil.
Davis D.
01-04-2005 05:08:58
Thanks for the info and comments. I understand those that that have been hurt by Wal-Mart and it's business practices. Web sites like this can only help the public to understand what they really get and do when they shop at Wal-Mart. I try to shop local and suppport my neighbors and friends however there are only so many dollars to go around and most everyone looks for the best buy. Thanks again.
dr.sportster
01-04-2005 04:55:58
Ww should not by any thing from this dirtbag commie outfit.they are killing small merchants.The way they treat the employees is the same quality of their oil.Learn API ratings and buy oil by them.
ntmcj
01-04-2005 08:10:10
 Re: Wal-Mart Oil in reply to dr.sportster, 01-04-2005 04:55:58
I don't know how they treat sales staff, but they treat their truck drivers pretty darn good. I am in the AF reserves and an activated reservist friend of mine is a Wal Mart truck driver. They have continued to pay his salary while he has been on active duty. He has been on active duty for almost two years now.
IHC Red
01-05-2005 03:11:22
 Re: Wal-Mart Oil in reply to ntmcj, 01-04-2005 08:10:10
Be assured... we'll hear about that in a commercial.
Ryan
01-04-2005 11:06:00
I read a study done on retail in rural areas after a Walmart located there. In short, where there are not other big box retail competition there was a net negative effect on the economy of the area, the hardest hit areas being those that are largely rural.
Ryan
buickanddeere
01-03-2005 23:10:38
After what Wally World has done for the small merchant, employee's wages/benefits and manufactured products from China. I'd rather be see entering a strip joint than Walmart.
Dan H
01-04-2005 07:22:23
 Re: Wal-Mart Oil in reply to buickanddeere, 01-03-2005 23:10:38
If you've ever been an employee for a "Mom & Pop" outfit in a small town you'd think Walmart's wages and benefits looked pretty good.
dhs
01-04-2005 04:10:29
Probably have more fun too!
Hermit
01-03-2005 21:27:43
According to what I've seen on other websites, the supplier varies. It depends on Walmart's oil spec requirements and who is the lowest bidder.
leland
01-03-2005 20:32:59
Ask JT he runs a small engine shop and he posted a while back that he gets trashed engines in all the time that people dumped walmart oil in.
Dug
01-03-2005 20:20:08
Valvoline bottles the WalMart oil.
Dug
Davis In SC
01-03-2005 20:14:59
I think I will continue using Rotella. Savings on off-brand oil are not worth the risk..... .
lucass
01-03-2005 19:36:07
my brother works for ashland oil and he said napa oil is valvoline. i dont know who makes walmart oil ,but some of my freinds use it and like it,but i use penzoil,i dont know why other than it seems to stay new looking longer than the cheep oils ..
kyhayman
01-03-2005 19:09:51
I noticed on the label it says Oil City, PA. Quaker State and Pennsoil both have that return addy on their label.
keystone
01-03-2005 19:08:11
Check out this web address. Has info on any lubricants out there. I did read a few weeks ago about the Wal-mart. The tests weren"t very good compared to other oils. Read about them and decide for yourself. I found it while scrolling through the message boards.
keystone
01-03-2005 19:05:29
keystone
01-03-2005 19:07:04
 Re: Wal-Mart Oil in reply to keystone, 01-03-2005 19:05:29
third party image
Sorry! Link
RJ-AZ
01-03-2005 19:02:31
I would like to know the supplier also. I use it in all my hi mileage clunkers which are all I drive anyway and it's working fine. It has a good clean smell kinda like Valvoline or Conoco. I think that the 15-40 would be fine in about any tractor.
Sid
01-03-2005 18:58:54
I understand that Napa oil is Valvoline as are many other house brand oils. If you look on the bottles you should be able to find who packaged the oil. I am fortunate enough to have a local source to buy my oil within two miles of my place. It is a locally owned True Value store and Wal-Mart has nothing over them. They have their house brand as well as name brand oils.
ntmcj
01-03-2005 18:44:06
I asked a friend a while who drives a truck for them. He said he thought Texaco was their supplier, but wasn't positive.
Ken S.
01-03-2005 19:35:52
 Re: Wal-Mart Oil in reply to ntmcj, 01-03-2005 18:44:06
I know Citgo,Shell and pennzoil are the same. We use the Wal-mart 15-40 in the big truck(3208 cat) at work and it seems to be just fine.
dhermesc
01-04-2005 07:34:53
 Re: Wal-Mart Oil in reply to Ken S., 01-03-2005 19:35:52
Didn't know Citgo was the same as Pennzoil. Bought two cases of Citgo from "Dollar General" last summer to use in an old dump truck I borrowed that was burning oil (a quart and hour). 10W30 and 10W40 were only .50 a quart. I think the 10W30 is headed for the Farmall this spring. Being SAE rated I figured it couldn't be too bad, if I'd know it was Pennzoil I'd have bought more.
dr.sportster
01-04-2005 13:18:07
 Re: Wal-Mart Oil in reply to dhermesc, 01-04-2005 07:34:53
I ,well my cousins buddy,knew aguy who worked in a diner across the street from a gas station where the mechanics sister dating the other mechanic from the other station down the block met a guy pumping gas on tuesdays who said wall mart oil was penn state,penn state,was harley oil but harley oil was B-P,baut B-P was,Singer sewing machine oil heavy duty,butSinger sewing machine oil was BMW oil but BMW oil was texaco oil but texaco oil was chevron but....
ntmcj
01-04-2005 21:45:16
 Re: Wal-Mart Oil in reply to dr.sportster, 01-04-2005 13:18:07
Everyone loves a smarta$$
