Tractor Talk Discussion Forum
onan engine rebuild kit?
Cy
01-04-2005 13:29:07
Hello does any one know where on-line i can find a onan engine rebuild kit?
Thanks!
msb
01-04-2005 20:16:50
 Re: onan engine rebuild kit? in reply to Cy, 01-04-2005 13:29:07
I have a 20hp Onan Performer out of a JD 910 mower that is low on oil pressure.Its for sale cheap,Indiana
BushogPapa
01-04-2005 16:32:14
When I rebuilt mine for my Bolins I found that the "small bore" and "Large Bore" Onans are the same block... The small bore block can be bored to the same as a large bore, and the price was about the same... What I ended up using was a new shortblock for a small BobCat that a fellow had and didn't use... I had to ues the old crank in the new block, so everything there is the same..!! Even all of the sheetmetal for the blower housing fit..!! Sure has a lot more power..Original rating for that mower was 16 HP--I would guess more like 20 now...(ofcourse I ported it and put seperate exhausts on it)... Here, we can get our Onan parts at the "Great Dane Semi-trailer dealership...Hilliard, Ohio.. One GOOD place to look for new discount Onan engines is at "Glen's Surplus" in Shelby, Ohio. I believe a complete NEW Onan 2-cylinder engine is in the range of $799.oo Complete all the way.. Ron..
rob gasper
01-04-2005 15:29:42
I have heard from a few diffent sources that Onan engines do not hold up after a rebuild, my suggestion would be to find a short block.
JT
01-04-2005 15:07:17
Cy, I can get you what you need, but it will not be cheap. If you will post what you need, with the engine numbers, I will get you some prices on the parts you need. Ot if you want, email me the info of what you need.
JT
Cy
01-04-2005 18:05:20
 Re: onan engine rebuild kit? in reply to JT, 01-04-2005 15:07:17
just set ya a e-mail.
Ultradog MN
01-04-2005 14:44:16
Howdy Cy,
You don"t mention which Onan...
Onan sold out to Cummins Engine a few years ago.
Cummins is the best place to get a kit that I know of. But get ready for a shock. They are pricey!! I was going to rebuild the 2 cyl CCKA Onan on my welder a couple of years ago and looked everwhere online to no avail. Finally my cousin steered me to a guy who had a new short block and I bought that instead. $800
I figure it was worth it.
I had at a couple of thousand hours on that engine before it needed Anything.
Good luck
Jerry
leland
01-04-2005 14:16:27
Leave a post here for JT he may be able to get what you need.
jc
01-04-2005 13:58:13
I have an Onan that is using oil and needs a starter. Was told by a local engine rebuild shop that the only source for Onan parts is John Deere.
(He knows my tractor is John Deere)There is a small engine parts supplier in a city near me that advertises Onan. I called them for the starter and was told they could get it. Didn't ask about the rebuild kit but intend to. I had no luck on the net. Might just buy a rebuild at the show in Febuary.
Cy
01-04-2005 14:13:22
 Re: onan engine rebuild kit? in reply to jc, 01-04-2005 13:58:13
where is the show?
