Tractor Talk Discussion Forum
jd 2040 brakes
David Smith
01-05-2005 17:51:00
I recently replaced the wet brake disc and plate on the right side. I did a total drain of hydraulic fluid to do this. know that I have it back together the lift and power steering works fine but I have lost brakes on both sides and they will not pump up. all the brake lines do is spit air. any ideas.
david val
01-09-2005 03:49:01
 Re: jd 2040 brakes in reply to David Smith, 01-05-2005 17:51:00
the brake valve reservoir is empty. you need to run the engine at high rpm for a few minutes to fill it up.
david
