Tractor Talk Discussion Forum
Torque converter
chrisfromsolitude
01-06-2005 19:49:00
Just exactly how does a lock up torque converter work? Why would you want it to lock up? Just wondering about it. Thanks
LUCASS
01-06-2005 20:11:30
 Re: Torque converter in reply to chrisfromsolitude, 01-06-2005 19:49:00
WHEN IT LOCKS UP IT GIVES YOU DIRECT DRIVE OF ENGINE TO TRANS INSTEAD OF FLUID DRIVE.IT LOWERS YOUR RPM AT CRUISING SPEED SO TO SPEAK..LUCAS
Bob
01-06-2005 20:09:12
A lock up torque convertor typically contains a hydraulically operated clutch that "locks up" or disables the torque convertor once you've reached cruising speed.
This eliminates "slip", resulting in a least heat generated in the transmission, and better fuel economy.
Early versions were operated by a combination of the hydraulic valve train in the transmission, and often a vacuum switch that would allow lockup only at lighter engine loads.
Nowadays, the engine computer decides when, and how firmly the convertor clutch should lock up.
chrisfromsolitude
01-07-2005 07:30:27
 Re: Torque converter in reply to Bob, 01-06-2005 20:09:12
So your saying that some today can lock up part way if the need calls for it? Thanks.
Bob
01-07-2005 07:35:03
 Re: Torque converter in reply to chrisfromsolitude, 01-07-2005 07:30:27
Some are operated by a pulse width modulated solenoid, and allow to slip a controlled amount.
