Tractor Talk Discussion Forum
C0-Op Maure Loader....
BushogPapa
01-08-2005 19:49:58
Anyone know what you have to do to tighten the piston seals on one of these..?? it is the one with the 2 side cylinders, with the chains wrapped around a loop, to the lower arms that have a roller in a slot that moves to raise the loader.. I believe dad said that they can be tightened while the cylinder is all together.. This old Co-Op loader has been on this JD "B" as far back as I can remember...only off for the mounted 226 cornpicker, or cultivating... Are these hard to find, now..?? Thanks for any help..!! Ron.
sjh
01-11-2005 13:58:05
 Re: C0-Op Maure Loader.... in reply to BushogPapa, 01-08-2005 19:49:58
I have one just like your loader. I have a cylinder apart right know. The seal is all leather. On the end of the cylinder there are 2 nuts. Take them off and pull the end out.Check the O-ring that is there. That might be the problem. My e-mail is open if you want some pictures.
J. Schwiebert
01-09-2005 19:07:10
Boy that loader goes back a few years. I get them ixed up any more but you are talking a templeton loader. If it is the piston seals are u-cups. The packing out on the hex nut is to seal the end of the cylinder. I worked on with about 25 years ago on A WD or WD-45 A-C. Another name is Caswell, but I think that was the loader with one cylinder. Questions?
BushogPapa
01-10-2005 05:22:11
 Re: C0-Op Maure Loader.... in reply to J. Schwiebert, 01-09-2005 19:07:10
This is the model that has 2 cylinders..one on each side, each attached to a chain that runs over a loop of channel iron--around to an anchor on the pivoting arms.. The arms sit in a mount on the front pedestal of the tractor, and reach down to the main channel irons, and lift from under the channel irons, in long slots..there is a roller in each slot.. The packing at the rod-end is OK..I need to tighten the Piston packing..some oil is getting past the pistons.. At the rear of these cylinders ( the closed end) there is a 1/2" hole...I think there is a possabillity that the piston can be pushed back to that end and a rod inserted, to register with something inside, and the rod rotated, to tighten the piston packing... Is this possible..?? This is a good loader, and I want to keep it working..!! Fellas would have us clean out their barns with that Late JD "B" with no muffler, as it didn't throw sparks like most tractors.. It still is my main dirt-mover and snow plow..!! Thanks for any ans all information..!! Ron.
J. Schwiebert
01-11-2005 05:23:13
 Re: C0-Op Maure Loader.... in reply to BushogPapa, 01-10-2005 05:22:11
That was the problem with the one on the A-C. We had to install new packing. They might not have all been made that way. I would pull one cylinder off pull the packing nut off the end and slide the cylinder apart Put new seals on the piston and you know you will be good to go.
BushogPapa
01-11-2005 05:26:47
 Re: C0-Op Maure Loader.... in reply to J. Schwiebert, 01-11-2005 05:23:13
Where in the World would I find new seals..????!!!!
Thanks..!!
Ron.
