Tractor Talk Discussion Forum
john deere model 401B hydraulics
Ken Tarrant
01-09-2005 09:57:51
I have a 401b that when you push the clutch in the hydraulics slow down and chatter, If you stop for a minute without the clutch pushed down it works fine for a minute.The hydraulics work best when the oil is hot. Any Ideas?
cannonball
01-10-2005 04:02:39
 Re: john deere model 401B hydraulics in reply to Ken Tarrant, 01-09-2005 09:57:51
need to know a little about tractor ...you have a reverser? ....your transmission pump stops when clutch is down...you either have a two stage clutch or a single with reverser...the 2 stage has to be set up right so that pto will keep running while you push clutch part of way down...the single with reverser has to be set up with reverser stoping tractor just pushing clutch about 2 to 3 inch...but to shift you must go all the way down and usually double clutch..check filter look for foreign material (brakes) also your screen may be plugged some...don't know it this helps but if not post back, there are plenty of people on here that will help...have nice day may god bless
Ken TArrant
03-20-2005 16:18:08
 Re: john deere model 401B hydraulics in reply to cannonball, 01-10-2005 04:02:39
Advice was excellent, tractor never worked as well as it does now since owned,like a whole new machine, cannot thank you enough.
