Tractor Talk Discussion Forum
Hdraulic Pump up date
Jerry L/AZ
01-09-2005 20:33:05
Thank you Two pop, ncWayne and J schwiebert for your help I was getting a bit cnofused It has been quite a while since I have worked on pumps. Now for the up date since they are the same pump type I took the right hand pump and turned the houseing around and got the rihgt rotation. just save my self a bunch of bucks. Jer
NC Wayne
01-10-2005 19:44:56
 Re: Hdraulic Pump up date in reply to Jerry L/AZ, 01-09-2005 20:33:05
Glad to hear things worked out for you.
J. Schwiebert
01-10-2005 03:42:08
Did you check the pressure plate traps? If they have one on each side you are O. K. if not well they will need to be turned.
Jerry L /AZ
01-10-2005 14:27:32
 Re: Hdraulic Pump up date in reply to J. Schwiebert, 01-10-2005 03:42:08
Yep two plates and two bronze or brass wear plates guy at pump shop says I should be good to go. Thanks Jer
