Tractor Talk Discussion Forum
variable speed transmision
dj
01-10-2005 08:23:56
does anyone know what would cause an mtd 6 speed high/low range variable speed transmision to slow down to stop in higher gears.
JK-NY
01-10-2005 17:23:00
 Re: variable speed transmision in reply to dj, 01-10-2005 08:23:56
I would check for loose/ worn drive belt . Does it have an ildler or variable pulley for your variable speed ? Those set ups are a little more sensitive to worn or loose belts. HTH
Zeek
01-10-2005 12:20:23
1. Foot on the brake.
2. Lack of fuel in the tank.
3. Closed throttle.
4. Lack of transmission fluid.
5. Little or no engine oil.
6. Key turned off.
7. Strong headwind or no tailwind.
8. Face to face with a yard ornament
9. One of the kids underneath.
10.Loose drive belt
11.Weeds or baling twine wrapped around a spindle.
RAB
01-11-2005 09:26:05
 Re: variable speed transmision in reply to Zeek, 01-10-2005 12:20:23
Ya misse the easy one - going up too steep a slope!
Regards, RAB
