Tractor Talk Discussion Forum
Kubota
JW BUCK
01-10-2005 10:48:45
L-35 Kubota recently had shuttle shift repaired. Tractor would not move. Now everything seems mostly ok except that while shifting gears, get a few second pause after clutch is released or while shifting on the go. No slippage after travel is resumed. ????? ????? ?????
Dave (IL)
01-10-2005 15:48:24
 Re: Kubota in reply to JW BUCK, 01-10-2005 10:48:45
Dang. For a second there I thought this said JW Buick!
kenneth macfarlane
01-11-2005 05:06:43
 Re: Kubota in reply to Dave (IL), 01-10-2005 15:48:24
The L35 has a glide shift tranny, there are adjustments for how snappy the shifts are in the valve body(s). Make sure they put the best Kubota Super UDT oil back in, generic oils don't meet kubota specs and you could fry the clutch packs. Make sure the filter is clean too.
I assume it is the main clutch and not the hydraulicly controlled clutch that was changed.
kenneth macfarlane
01-11-2005 05:08:39
 Re: Kubota in reply to kenneth macfarlane, 01-11-2005 05:06:43
Sorry, thought you said clutch not shuttle, most likely the solenoids got tinkered with.
May want to get them adjusted, you'll find if you go to shift going downhill it is quite a ride!
kenneth macfarlane
01-11-2005 05:10:13
 Re: Kubota in reply to kenneth macfarlane, 01-11-2005 05:08:39
I'll get this all out eventually! The solenoids run the valves on the newer models of glideshift, maybe this older model just has hydraulically activated valves.
JW Buck
01-12-2005 07:44:56
 Re: Kubota in reply to kenneth macfarlane, 01-11-2005 05:10:13
1995 or 1996 model. Are adjustments something a Kubota dealer or mechanic would have to do?
