Tractor Talk Discussion Forum
Oliver 1365 Hydraulics
Michael Strong
01-10-2005 12:16:28
Hi Guys, I have a 1365 and the hydraulics are weak all of the sudden. I cleaned the filter but still no power. The remotes started to weaken and then the 3pt. I drained the system and then refilled it. Thought I had air in the lines so unbolted at the pump and oil came out all over. Bled them all the way to the back but still no real power.
Any ideas?
Thanks
J. Schwiebert
01-10-2005 17:12:56
 Re: Oliver 1365 Hydraulics in reply to Michael Strong, 01-10-2005 12:16:28
Does the hydraulic system make any noises? Have you had a pressure gauge on one of the lines going to the cylinder. At least all we sold had remote valves for cylinders. What are you using for hydraulic fluid?
KEH
01-10-2005 16:23:05
I have a Long 610 that I bought new in 1980 which is about the same as the Oliver 1365, just made from cheaper material. Some advice on hydraulics based on experience: If you have the metal mesh strainer, you may need to replace it, not just clean it. There are copper crush washers in the hydraulic controls that I had to replace when the hydraulics got weak but I am afraid I don"t remember all of them. There is a good local dealer if you want to call 864 682 3652 and ask for Lewis Power. He can advise on the washers. I don"t think you have air in the lines. In the worst case, you may have to replace the hydraulic pump. In another worst case, you may have to repair or replace the expensive hydraulic controls under the seat. By the way, a few months ago someone in the area had a 1365 with a bad motor. Hope this helps.
