Tractor Talk Discussion Forum
hercules zxb
Jim Peterson
01-12-2005 18:05:12
hi i have a zxb in a ww2 hobart generator did they ever put them in tractors looking for a backup motor thanks jim
Jim Peterson
01-14-2005 10:29:44
 Re: hercules zxb in reply to Jim Peterson, 01-12-2005 18:05:12
hi thanks for the info zxb has a 25/8 bore an a3 in stoke the water pump is gear drive The genset is3000 watts and turns at 1200 rpms I live in the U P of michigan thanks Jim p.S. its a 4 banger
BLW
01-14-2005 07:50:00
jim is it a 6 cyl-- if so it is prob. a jxd-- any way i have an old book that tells what vehicles had diff herc. engines-- alot of buses had them look and see if it is not a JXD- if not tell me how many cyl.s and what size mach and i can prob find out had them if I can be of any help== I still have a hough payoader w/ a JXB in it and some final drive gears for oc12"s oliver crawlers etc.
J. Schwiebert
01-13-2005 12:58:18
I forgot to tell you this morning but your engine will be built to Military Standard Specs and no boubt is a ZX with 5 timing gears. The tractor engine only have 3. Also not all parts will interchange directly. How hard have you looked for an engine?
J. Schwiebert
01-13-2005 04:21:52
The ZX was used in the little Avery & Moline model V tractors. Where are you located?
old
01-12-2005 20:16:23
Thats a new one on me I've heard of the IX series but till now never and ZX. The IXs where used in cletrac crawlers
