Tractor Talk Discussion Forum
international 600 D
d.a.halland
01-14-2005 11:40:04
i have a 600 diesel that i'm having a hell of a time with.runs perfectly on gas,but absolutley can't make it run on diesel. did some pump work'found a couple of stuck plungers and a couple of broken springs. i think the timing jumped some how,because when you turn the dial inside the timing cover i just doesn't seem to change the way it runs. the injectors have been check out,the head has been redone, did compresion ,someone out there has had the same problem i know they have.so you older ih guys that know all the little tricks, how about send me the trick before i go into the ih nut house. thanks ih guys
geok
01-14-2005 14:28:42
 Re: international 600 D in reply to d.a.halland, 01-14-2005 11:40:04
One thing to check is to make sure the butterfly shaft that is controlled from the back side of intake manifold next to block is working freely when you switch from gas to diesel.
When you attempt to run on diesel, is there a lot of smoke coming out of stack?
