Tractor Talk Discussion Forum
Changing water filter on Cummins 8.3
MX240
01-14-2005 20:39:09
I'm trying to change the coolant filter in an Case-IH MX240. The manual just shows an arrow pointing to the general direction of the shut-off valve. I do not see the shut-off. I do see somthing that looks like it could be turned, in the casting that the filter screws to, but it won't budge.
edchainsaw
01-15-2005 19:18:30
 Re: Changing water filter on Cummins 8.3 in reply to MX240, 01-14-2005 20:39:09
had a similar problem with our combine's filter... never did get it to shut clear off
Fudd@work
01-14-2005 20:49:48
That flat piece on top of the casting will turn sideways to shut off the coolant flow to the filter. If it is stuck, spray some WD-40 on it and gently rock it back and forth being carefull not to break it. If you need to replace it, that small screw on top holds the valve in and it has 2 0-rings on it. The Cummins dealer should have the valve and o-rings.
