Tractor Talk Discussion Forum
Brakes Freeze??
wolfmantractor
01-16-2005 14:31:27
Very cold weather, started down road with 684 loader tractor and in about 1/2 mile acted like brakes were slowly and steadily applied. Had to stop, check it out; let it sit at 7-800 rpm for ten minutes and everything seemed free. What froze up?
Gene Davis (Ga.)
01-16-2005 19:13:35
 Re: Brakes Freeze?? in reply to wolfmantractor, 01-16-2005 14:31:27
Probably had a little bit of water in the fluid and it frize.
Gene Davis (Ga.)
01-16-2005 19:17:53
 Re: Brakes Freeze?? in reply to Gene Davis (Ga.), 01-16-2005 19:13:35
Please excuse all the extra posts, My computer is nutty. I don't ind any body deleting the extra if you know how. Thanks Gene Davis
Gene Davis (Ga.)
01-16-2005 19:11:28
Gene Davis (Ga.)
01-16-2005 19:03:22
Mark - IN.
01-16-2005 18:45:48
Brakes? "Drop the loader! Drop the loader" as I scrambled out of the way. Gonna have to fix that.
Mark
Gene Davis (Ga.)
01-16-2005 18:39:21
rustyj14
01-19-2005 17:42:34
 Re: Brakes Freeze?? in reply to Gene Davis (Ga.), 01-16-2005 18:39:21
Gene: Sounds like you'd better check with Punxsutawney Phil. He'll tell when its safe to run yer machine. We've only got 2-3 weeks fer him to give out his annual prediction, and then we'll know when to get the machines out for spring! Hope you get yer computer to stop whatever it's doing with multiple messages! Did you lean on the "repeat" button. or set yer beer above it? the fumes from the beer can get the box confused, don'tcha know! by: Rustyj
