Tractor Talk Discussion Forum
Busted the blade on a Frozen Cow Pie AGAIN!
Willy-N
01-16-2005 17:31:32
This time I busted the other lower 3 point hook up pin on the rear blade! Darn Frozen Cow Pies! Snapped that baby off clean moving forward slow this time and it swung the blade around and snapped the 1 inch thick upper eye bolt on the end of the upper link bar!! So now I am all new again on the hook up points. I figure that over the years the metal just work hardend to the point of fracturing. Time will tell winter still has a ways to go and plenty of hidden Cow pies in the snow. Mark H.
Mike M
01-17-2005 05:26:48
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Willy-N, 01-16-2005 17:31:32
Look around and find yourself a good used John Deere blade I found a # 115 with a 9 foot blade for dad for $800 we use it on the 4020. These are a very good blade.
Brian RM
01-16-2005 18:38:10
Willy- What state are you in where its that cold?
Willy-N
01-16-2005 18:49:46
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Brian RM, 01-16-2005 18:38:10
I live outside of Okanogan, Washington State on the East Side of the mountian 50-60 miles South of Canada at the 2,800 ft level. Mark H.
T_Bone
01-17-2005 02:41:28
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Willy-N, 01-16-2005 18:49:46
Hi Willy,
I spent some time above Conconully (sp) looking over the old Ruby mine tailings. Was quite interesting how they all got hoodwinked from a US Senator from Portland,Or in the 1800"s. Geez can"t remember his name, too many moons ago.
Nice area tho as I spent 3mths there.
T_Bone
Willy-N
01-17-2005 10:56:33
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to T_Bone, 01-17-2005 02:41:28
That is a neat town. To bad there running out of money and coruption in the Town Elected oficials spending what was left of it. Mark H.
Jerry/MT
01-16-2005 18:21:55
Mark, you mean you don't have a chip detector on that tractor of your!? (grin)
Willy-N
01-16-2005 18:54:06
 Re: They only stick where I plow in reply to Jerry/MT, 01-16-2005 18:21:55
They only stick to the ground where I plow to the dirt for them to lay and eat on. Then the cow pies will stick good being nice and wet at first. Other wise they freeze off the ground and not a problem. I had to clean the barn today! Mark H.
paul
01-17-2005 12:17:30
 Re: They only stick where I plow in reply to Willy-N, 01-16-2005 18:54:06
Shouldn't they lay on the snow in this weather? Better insulation than the cold ground???
Mine will lay on an old bale first, snow second, dirt third, and rarely lay on the concrete when it is this cold when given choices. Bout the same for feeding.
Of course, we only have an inch of snow this year, and when we have more on a normal year (40 inches or so) it gets whipped into a hard bank, perhaps you get a different snowfall.....
--->Paul
Willy-N
01-18-2005 19:00:22
 Re: They only stick where I plow in reply to paul, 01-17-2005 12:17:30
They have straw in the barn if they want to lay in there. It seems they like the cleared area when the suns out. Since I have to clear it to do the barn they all go out and stand or lay in it when I am done? Mark H.
Willy-N
01-16-2005 18:30:13
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Jerry/MT, 01-16-2005 18:21:55
It has been 6-10 below Zero so them little I mean BIG Chips are realy stuck down like a concrete roar turtles!! They even have a lip to snag all the way arounf them! I even had the blade tilted a little to skip over stuck things!! Mark H.
Nebraska Cowman
01-16-2005 18:16:25
No easy solution. back blades are not designed to plow snow but they are a cheap alternitive to the real thing. I guess you take the bad with the good.
Willy-N
01-16-2005 18:32:23
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Nebraska Cowman, 01-16-2005 18:16:25
If I ever get a new one I will be adding all kinds of gussets and things to beef it up with befor it starts breaking. Mark H.
Jonboy
01-16-2005 20:34:09
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Willy-N, 01-16-2005 18:32:23
If you decide to get a new one, go buy a King Kutter, thats what we did and we bought one rugged enough so the tractor would spin before it broke. Works real good and isn't painted an expensive color. Only problem I have with it is it's very heavy and doesn't have a stand, so we use an old army gun crate to set it down on when we are not using it so we can just back right up and hook up.
Willy-N
01-16-2005 22:46:13
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to Jonboy, 01-16-2005 20:34:09
I will have to look at one. Heard a lot of good about that style. The upper Pin Mount on mine was a rod that went all the way across the front and the ends were turned down to Cat 1 Pins. I think that is what made them a weak point. The pins I have now are 6 inch long ones with the big nuts on them welded into place using the nuts and shaft. Much stronger point now. Mark H.
kjm
01-16-2005 20:22:38
Willy-N, It could be worse,I have a heavy Land Pride blade that I haven`t hurt but I broke the hitch on my D-17 and the two point to 3-point addpter on the Super C. At least we haven`t had any snow that stayed on more than 24 hr. God Bless,kjm
Willy-N
01-16-2005 22:41:40
 Re: Busted the blade on a Frozen Cow Pie AGAIN! in reply to kjm, 01-16-2005 20:22:38
The Link Bars on the Massey 135 are real thick and strong don't think they would bust to easy. I was suprised to break the upper link it was a original one and a Cat 2 Pin 3/4" Rod thru a 1 inch Eye fine thread bolt! Mark H.
