Tractor Talk Discussion Forum
Sticky Valve?
JKC
01-16-2005 20:31:51
I have a 1950 MM ZAU that I have been told probably has a "sticky" valve. What is the most likely cause of this? What should I be looking for as the culprit component?
What are some of the "symtoms" of a "sticky" valve?
Thanks.
Reddog
01-17-2005 18:00:12
 Re: Sticky Valve? in reply to JKC, 01-16-2005 20:31:51
When I was a boy I remember my dad would put Liquid Wrench Penetrating oil in with the oil and I think some in with the gas on his Farmall when he had a sticky valve.
Mo Hay Baler
01-17-2005 15:33:46
Get a good insulated pair of pliers,and pull plug wires off one at a time.It will be the one that doesnt change difference in running that has stuck valve
37 chief
01-17-2005 00:17:05
This is what happened to me last year. I had some really old gas, so I thought I would mix it with some good gas and add it to my tractor. This was a big mistake. I got a real bad case of sticking valves. I actually had to remove the valve cover and tap the valve to get it to seat again . I added some Rislone to the oil and the problem eventully went away. Old gas was what caused my problem with valves sticking. Stan
