Tractor Talk Discussion Forum
starter problem 3930 Ford New Holland
william in WI
01-20-2005 17:17:19
I am trying to remove my starter. I removed the two bolts I see. It doesn"t budge. Am I missing a bolt? I can"t see it. Any other forums I should check?
Chuck - WI (Wausau)
01-21-2005 10:57:38
 Re: starter problem 3930 Ford New Holland in reply to william in WI, 01-20-2005 17:17:19
Since you're working on the 3930, I'll pass on two comments from another WI-ite. Check your front bolts .. motor to steering assembly .. found they worked lose last fall .. added locking washers ..... ..
2nd .. look at the power wire to fuel pump connection .. thought I had bad fuel or filters .. worked 95 % of time, sometimes just died without warning than worked again .. wasted a lot of time chasing the wrong problem .. finally ended up at dealer .. wire flexed (bumps and bounce) at connector, killing pump until it flexed back for a partial connection.
pcy1066
01-20-2005 18:34:32
there is a third bolt on the back side
