Tractor Talk Discussion Forum
LEAKY CARBURATER
FRANK
01-22-2005 16:10:11
I,M HAVING A PROBLEM WITH FLOODING ON MY FARMALL "M" AS SOON AS I TURN ON THE GAS TO START IT. IS THIS A COMMON PROBLEM AND IF SO IS THERE A REMEDY? THANKS
dr.sportster
01-23-2005 10:38:58
 Re: LEAKY CARBURATER in reply to FRANK, 01-22-2005 16:10:11
If you plan to solder a pinhole make sure to get all the gas out or the float will still be heavy.Not too much solder or it will be heavy.Sometimes these repairs become double work and a new float is in order.
deadeye
01-23-2005 00:28:33
What the other post are talking about as a sunken float, is one with a hole in it that you cannot see. Gas will get inside of it and make the float heavier. Shake it vigeriously when you have it apart to see if this has happened along with seat replacement and properly adjusting float height and drop with gasket in place...deadeye
Rockin' Farmer
01-22-2005 22:49:42
Frank,
Sounds like ya got a stuck or sunk float or needle valve is shot. If the float is stuck, sometimes tapping on the carburetor will free it up, but that's not really a fix. Carb kit is probably in order.
Good luck,
Rockin' Farmer
old
01-22-2005 18:13:41
Sounds like you need to rebuild the carb since either the flot is stuck and or the needle/seat is bad
bo
01-22-2005 16:12:54
float stuck...clean
Matt-in-ontario
01-22-2005 17:32:01
 Re: LEAKY CARBURATER in reply to bo, 01-22-2005 16:12:54
An old auto shop teacher used to make us practice spelling "carburetor" before we were allowed to work on one. I learned how spell it but not fix it.
dr.sportster
01-23-2005 10:33:22
 Re: LEAKY CARBURATER in reply to Matt-in-ontario, 01-22-2005 17:32:01
Hey Matt,Im pretty sure you spelled it wrong and theres two correct ways.Canadian service manuals use More Brit style lingo.CarburettorIs on My Weber book.CARBURETOR in my 1962ford falcon manual.There might be three correct spellings.[You are correct,sorry]
