Tractor Talk Discussion Forum
mf 1155 blow by/ air leak
Wes Miller
01-23-2005 11:44:46
i have a MF1155 with 5700hrs and a lot of blow by any way to fix other then a rebuild. also it hase an air leak in the fuel system that makes it hard to start after siting over night. it will fie right of then stalls out and requires a lot of cranking and either and sometimes bleeding the lines
RAB
01-24-2005 09:50:27
 Re: mf 1155 blow by/ air leak in reply to Wes Miller, 01-23-2005 11:44:46
If it needs a rebuild, there ain"t really any other way than tear it down - BUT is that what is causing the blow-by? Maybe it just needs a lot of hard work to unglaze the bores (from only doing light duties?)
Only you can fix your leak - it is possibly on the spill-return lines from the injectors.
Regards, RAB
