Tractor Talk Discussion Forum
NAA hydraulic problem
J Adkins
01-24-2005 10:02:59
This winter I have had a problem where the hydraulics won"t work on my Ford NAA until I take loose one of the hoses, while it"s running, which spills oil on the floor, but then it works. At times, I noticed the fluid being foamy and white? I"m told the pump is not being primed and may need the pump re-built? Not sure if I have a vane or piston pump? How do I tell? It says "hy-trol" on the right side with an adjusting nut. Other than have the pump re-built, what should I try? Change the oil? If so, what kind should I use? I"m not necessarily looking for the cheapest solution, but the best solution in the long run. Thanks in advance for any help!
msb
01-24-2005 20:44:11
 Re: NAA hydraulic problem in reply to J Adkins, 01-24-2005 10:02:59
Drain the oil and replace with new oil.Your oil has water in it.It may take a long time for it to all drain out and you might have to change the oil again soon afer replacing what you have in there now to finally get all the water out of the system.There are lots of nooks and crannies in that reservoir.
j adkins
01-25-2005 10:40:32
 Re: NAA hydraulic problem in reply to msb, 01-24-2005 20:44:11
ok, I will drain it and put in new oil. What kind of oil should I use? Thanks for the help!
Tim...OK
01-24-2005 14:09:52
Try asking your question on the 2/9/8N forum,a bunch of those guys have NAA's also,should be able to fix you up.. Possibly water in oil then freezing??
Tim
