Tractor Talk Discussion Forum
What does this starter fit.
old
01-24-2005 17:17:51
Its an auto-lite 4072 starter has a 2 bolt flange on it and what I would call an open end. Thanks
Alberta Mike
01-24-2005 20:18:50
 Re: What does this starter fit. in reply to old, 01-24-2005 17:17:51
It also fits the 101/102 Massey Harris series of tractors plus the Case model V (not the VA's).
Duner Wi
01-24-2005 17:56:21
If it is a MZ4072 my book says it will fit a 1952-57 Cockshutt 20 or 1947-56 Massey 20,20K,21 Colt,22K and 23K. No guarantees.
Alberta Mike
01-24-2005 20:20:17
 Re: What does this starter fit. in reply to Duner Wi, 01-24-2005 17:56:21
Just out of curiosity, what book is that you are referring to?
Duner Wi
01-25-2005 06:15:50
 Re: What does this starter fit. in reply to Alberta Mike, 01-24-2005 20:20:17
I have a Wilson and Neihoff catalog but only go back to 1947 or so. You have better books than I.
Alberta Mike
01-25-2005 11:50:47
 Re: What does this starter fit. in reply to Duner Wi, 01-25-2005 06:15:50
I have two mystery parts here.
1. Delco-Remy Generator - #1101859 6A 9
2. Delco-Remy Starter - #1107178 4D 10
Thanks for your help.
Duner Wi
01-25-2005 17:13:59
 Re: What does this starter fit. in reply to Alberta Mike, 01-25-2005 11:50:47
1101859 6 Volt Delco Gen. fits J-D 320,330,40,420,430,440,M69 and M70.
1107178 6 volt Delco starter used 1959-64 on M-F # 35 SP combine, 34 swather and 44 windrower. I think these were powered by 4 cyl. Continentals but I don't know which one. The MF tractors were 12 volt by about 1956 for the TO's and about 1951 for the TE's. Wilson Auto Elec. in 1965 was based in Winnepeg, Manitoba. Hope this helps. Usual disclaimers apply.
Alberta Mike
01-26-2005 03:51:44
 Re: What does this starter fit. in reply to Duner Wi, 01-25-2005 17:13:59
Thanks for the information, it is very helpful.
Alberta Mike
01-25-2005 06:39:27
Never heard of that book but it sounds interesting. Actually, I just happened to know the two applications I mentioned because I have a 101 MH Junior and a Case V and they both use that starter. I don't have an application book like that, I must check around for one. I have a starter here that is also a "mystery" to me for application, I will hunt down the make/model and post it here, maybe you can see what your book says. I will get back to you later today on this forum site.
