Tractor Talk Discussion Forum
8N 3 point lift
Randy Hagan
01-25-2005 10:35:40
I just bought an 8N and got it running great thanks in part to this site. My next project is the hydraulic system. It works fine, but it shakes when it is in the up right position and the engine is running. If I shut the engine off, it drops in less than a minute. Common? Repairable? Dont worry about it? I have read that they will lift 800 lbs. I don"t think this one will. I have a gannon on it and I put a wheel weight on it to give it more weight, and it lifts it no problem. Any input is appreciated. Thanks.
Flathead
01-25-2005 12:49:04
 Re: 8N 3 point lift in reply to Randy Hagan, 01-25-2005 10:35:40
Just click on "Articles" under "Research and Info" to the left of this page. Zane"s 8N hydraulic troubleshooting guide is at the top of the list.
Flathead
Bob
01-25-2005 10:46:58
SOME shake is normal, with a heavy load. There are several places the lift can leak causing it to go down quickly when the engine is shut "OFF"... lift cylinder, pressure relief valve, control valve, gaskets, etc..
For troubleshooting informaion, go to the "N" board and search the archives for "N" hydraulic guru Zane's lift troubleshooting instructions.
