Tractor Talk Discussion Forum
8N 3 point lift
Randy Hagan
01-25-2005 12:19:44
The 3 point on my tractor shakes up and down when in the upright position and the engine running. It drops when the engine is shut off in less than a minute. I have a gannon with a wheel weight on it. It lifts it no problem. I have read that it will lift 800 lbs. I don"t think this one will. It is a 1950 8N. Should I be concerned or is this normal?
WiCraig
01-25-2005 13:00:40
 Re: 8N 3 point lift in reply to Randy Hagan, 01-25-2005 12:19:44
Pretty normal for an old machine, worn piston, bad releif valve, etc. Can be fixed but I just lived with it on mine. Pain in the A though, as the 3pt drops every time you push the clutch in. You should get alot of replies on this. Look in the archieves, tons of info on this topic. Craig
Randy Hagan
01-27-2005 19:49:11
 Re: 8N 3 point lift in reply to WiCraig, 01-25-2005 13:00:40
Thanks Craig.
