Tractor Talk Discussion Forum
Need specs on resurfacing flywheel on MF175 ASAP!
shocker
01-25-2005 13:14:15
I am trying to find out ths depth so my machine shop can resurface my flywheel correctly since you have to do it in 2 steps, the disc surface and the 6 bolt surface that holds the assy. on the flywheel.Please Help ASAP!!
Farmered
01-26-2005 05:02:41
 Re: Need specs on resurfacing flywheel on MF175 AS in reply to shocker, 01-25-2005 13:14:15
The amount you take off is not critical but it is important to take the same amount off the bolting surface as you do off the friction surface. The spline on the transmission input shaft allows quite a bit of machining to be done. I certainly would not put any shims between the crank and the flywheel. You won't be able to keep the flywheel tight. Ed
RickB
01-25-2005 15:04:36
 specs on resurfacing flywheel on MF175 ASAP! in reply to shocker, 01-25-2005 13:14:15
According to Hy-Capacity's online catalog it should be 1.170" for double clutches or 1.410" for single clutches.
shocker
01-25-2005 16:13:11
 Re: specs on resurfacing flywheel on MF175 ASAP! in reply to RickB, 01-25-2005 15:04:36
I do not understand which one i would have,it has a drive and a PTO clutch but i thought every tractor has two?What do you think?
Bob N.Y.
01-25-2005 17:39:15
 Re: specs on resurfacing flywheel on MF175 ASAP! in reply to shocker, 01-25-2005 16:13:11
A 175 could have live pto with a 2-stage clutch or independent pto with a single clutch.
RickB
01-25-2005 17:24:04
The last thing I will ever claim to be is a Massey expert. If you don't know if you have a single or double clutch, how did you order parts?
shocker
01-25-2005 18:12:32
 Re: specs on resurfacing flywheel on MF175 ASAP! in reply to RickB, 01-25-2005 17:24:04
Your right Bob,It is a dual clutch thanks for the spec. How do you know if the flywheel has enough material to be turned again since the tractor is 35yrs. and i do not know how many times it has been re-surfaced?
napaguy
01-25-2005 19:58:56
 Re: specs on resurfacing flywheel on MF175 ASAP! in reply to shocker, 01-25-2005 18:12:32
if the shop takes, say, .030 off you put a .030
shim between the crankshaft and flywheel.
