Tractor Talk Discussion Forum
oliver 77 clutch,reline?
mssylvr
01-25-2005 15:34:13
Ok I got it all apart,should I send clutch disc out to get relined,just buy a new one,and should I resurface the pressure plate even though it looks good?I know,a lot of questions but it needs to be done right and also economically.Thanks
Larry from MD
01-25-2005 15:48:48
 Re: oliver 77 clutch,reline? in reply to mssylvr, 01-25-2005 15:34:13
Normally the springs in the preasure plate get weak from heat,so a resurfaceing is not much help.Years ago you could buy the springs and rebuild yourself.I have had the other parts break on clutches that have lots of age on them,so now most of the time people buy a rebuilt preasure plate to get all the parts new.If there is lots of wear on the disc you should replace that to.I have had a number of oliver clutch disc break out the springs.
mssylvr
01-26-2005 04:58:51
 Re: oliver 77 clutch,reline? in reply to Larry from MD, 01-25-2005 15:48:48
Thanks Larry,think i will invest in all new and be done with it.Ralph
