Tractor Talk Discussion Forum
Re: PTO cement mixer instructions wanted
Bill WI
01-27-2005 07:37:01
I use my own gravel which is sandy and buy in a truckload 3/4 inch crushed stone. I use 4 sand , 1 crushed stone and 1 portland cement. If I have something real strong I use 3 sand. I'd use 5 to 1 of yours and to for tough jobs use 4 to 1. Keep your mixer running slow enough so the cement follows the paddles and drops at about the top. Too fast and it'll just follow around. too much water and it'll just stay pudding in the bottom and not strong enough for nothing. You get used to it.
Rod in Smiths Falls, ON,
01-27-2005 16:28:07
 Re: PTO cement mixer instructions wanted in reply to Bill WI, 01-27-2005 07:37:01
So the problem with the mixer was really with the tractor. Maybe I should try the thing again with the newer MF35 diesel. It can turn over at about 400 rpm without losing oil presssure.
Thank you for the clear instructions.
Rod
