Tractor Talk Discussion Forum
6v. to 12v. convers. on Ford NAA '53 Jubilee
Corndog
01-27-2005 14:03:46
Installed a Delco-Remy 12v. alt. It has a Batt. hook up, a field and a resistor hook up. I got the BAT. wired to Pos. cable. Field wired to BAT. My question is where do I wire the "R" to? I still have 6v. solenold. I have a resistor in front of coil. Need help help before I fry it all. Send a diagram if possible. Thanks a million.
Keith-OR
01-27-2005 21:38:17
 Re: 6v. to 12v. convers. on Ford NAA '53 Jubilee in reply to Corndog, 01-27-2005 14:03:46
This is basically the same as yours. Easy to follow.
sbill
01-27-2005 20:51:51
on your 10 si delco alternator if you will use 1770 se regulator inside the alternator you will only need to use a battery wire it is a self exciting regulator i build them all the time for tractors alot of your parts stores have what they call a one wire alternator good luck
john in la
01-27-2005 14:58:53
First off are you using a Delco 10SI alternator??
It will look like this from the back.
third party image
If so read on..... ..... ..... ..... ..
Read This first as it should answer any questions you have. It was written for the hundred series but will work on you NAA.
The differances will be you only have a 3 wire starter relay so it does not have the wire from the terminal block to the relay.
You do not have the dash light so you will need to use a one way diode.
Some have mentioned the wiring diagram is to small to read so Here
is a larger copy.
If you have any questions ask away.
Corndog
01-27-2005 18:14:48
 Re: 6v. to 12v. convers. on Ford NAA '53 Jubilee in reply to john in la, 01-27-2005 14:58:53
John in LA Thank you so much for your great information on the 12 volt conversion. I appreciate your quick response. I will begin work on it asap. By the way, I'm from Louisiana, too. Are you from LA (Louisiana)
THANK YOU AGAIN VERY MUCH
Corndog from Keithville
john in la
01-27-2005 20:41:21
 Re: 6v. to 12v. convers. on Ford NAA '53 Jubilee in reply to Corndog, 01-27-2005 18:14:48
Yes....
The N.O. area.
old
01-27-2005 14:29:59
The field wire goes to the switch on the cold side I.E. hot when switch is on. ON a lot of the the other wire doesn't have to be hooked up or you can hook it to a lite to show you its working
Corndog
01-27-2005 17:52:53
 Re: 6v. to 12v. convers. on Ford NAA '53 Jubilee in reply to old, 01-27-2005 14:29:59
Thanks so much, Old. I will try it tomorrow.
