Tractor Talk Discussion Forum
Case HTO Additive
Tug man
01-29-2005 08:45:02
This product is used in some Case skid steers in the hydraulic system. I have 5 gals of 15-40 motor oil and this product pre mixed that I would like to use as engine oil. Is there anything in this product that would would be bad for the engine ? In the bottle, the HTO smells somewhat like Marvel mystery oil, if that means anything.
James2
01-30-2005 18:17:09
 Re: Case HTO Additive in reply to Tug man, 01-29-2005 08:45:02
I don't think I would use it in an engine. It's an extreme pressure anti-wear additive: ie a Zinc-Phos compound in SAE 30 or 20W base oil. You all ready have a good amount of this additive if you are using a diesel oil which I assume if it is a 15W40. It does great things for hydrostatic pumps/motors and hydraulic systems. HyTran (sp?) does not contain any because it causes more clutch/brake slip. I always add it to HyTran if it is not in a brake or powershift compartment which has clutches. They removed much of the Zinc-Phos in gasoline engine oil because it plugs the Cat converter. I have considered putting some into gas oil, because it has good anti-wear properties, but have decided not to screw with the OEM's formulation.
Tug Man
01-30-2005 19:30:15
 Re: Case HTO Additive in reply to James2, 01-30-2005 18:17:09
Thanks for the advice, James2. It was exactly what I wanted to know !!
RAB
01-30-2005 08:52:32
Thought of asking the manufacturer?
RAB
dr.sportster
01-29-2005 09:09:03
Sounds like you have 5 gallons of chainsaw blade oil.
