Tractor Talk Discussion Forum
Retrofit R.O.P.S.
JJ855
01-31-2005 05:58:51
Is there a safe way to build a homemade ROPS for my 59 Ferguson 35? I have a stick welder. I am afraid of failure in a rollover.
buickanddeere
01-31-2005 23:15:45
 Re: Retrofit R.O.P.S. in reply to JJ855, 01-31-2005 05:58:51
Should you go ahead, proceed with caution. Could you find a rops from a similar sized/brand tractor and retro fit? The engineering is exspensive and extensive. Several rops & tractors get written off as wrecks by the factory testing until they get it right. If the rops is too stiff there is no give, it or the tractor chassis will break unstead. If a weld doesn't workout quite right, wrong steel alloy used or design problems. The rops will fail. Even if the rops is perfect the tractor chassis has to be designed to work with a rops. Should an exle or trans/bellhousing snap under stress. The driver would be in danger. An engineered seatbelt will also be required. It's impossible to hang on in a rollover. Worse than embarassing getting crushed by the rops you built. I rolled a machine last year when a ditch bank caved in. Scared me something serious as that seatbelt I almost didn't repair and use. Kept me from being crushed under the escavator.
jj855
01-31-2005 07:32:51
I didn't intend to block my e mail. Phone #is 330 212 7452
Dean Barker
01-31-2005 06:32:07
Or call me at 641-732-4802
Dean Barker
01-31-2005 06:29:25
I can help you. Open your e-mail or list your phone number and I will reply.
Hugh
04-29-2005 19:36:18
 Re: Retrofit R.O.P.S. in reply to Dean Barker, 01-31-2005 06:29:25
I'm looking for a ROPS also for my 1958 MF 35. Can someone help? The dealer claims none is available.
