Tractor Talk Discussion Forum
FORD 4000 LEAKING FROM EXHAUST
MISTER T
02-01-2005 20:52:30
I RECENTLY PURCHASED A 1973 FORD 4000,MY FIRST DIESEL TRACTOR.YESTERDAY I NOTICED WHAT LOOKED LIKE BLACK TAR LEAKING FROM THE EXHAUST MANIFOLD WHERE THE STACK CONNECTS TO IT.WHAT IS THIS AND IS THIS ANYTHING TO BE CONCERNED WITH? THANKS
George in Biloxi
02-02-2005 08:29:31
 Re: FORD 4000 LEAKING FROM EXHAUST in reply to MISTER T, 02-01-2005 20:52:30
I had the same problem. An injector was bad, replaced, and it went away.
MISTER T
02-02-2005 17:50:18
 Re: FORD 4000 LEAKING FROM EXHAUST in reply to George in Biloxi, 02-02-2005 08:29:31
THANKS FOR ALL THE REPLYS.I WILL WORK IT A LITTLE HARDER,IF THAT DOES NOT WORK I WILL REPLACE THE INJECTORS.
brtx
02-01-2005 23:48:47
just another thought.you said stack on exhaust.if itis vaertical do you have a rain cap or is it covered?it may be moisture causing the problem
RustyFarmall
02-01-2005 21:36:30
The black tar substance is nothing more than unburnt diesel fuel. You need to work the tractor a little harder. Get it warmed up good every so often and that black goo should go away. If you need to, take it out on the road and run the engine wide open for a couple of miles.
RAB
02-01-2005 23:16:05
 Re: FORD 4000 LEAKING FROM EXHAUST in reply to RustyFarmall, 02-01-2005 21:36:30
2 miles @ top speed represents just about 8 minutes - barely enough time to burn the deposits out of the exhaust but not enough to prevent the bores glazing, with loss of compression, more blow-by and worsening symptoms. The engine needs some genuine hard work on a regular basis. Also check it is running at thermostat temperature, not below. If you continue to run in this manner, you can expect a big overhaul bill for compared with the amount of work the tractor has done.
Regards, RAB
