Tractor Talk Discussion Forum
Onan loses power
Jack at LL
02-02-2005 13:33:42
(I posted this on another forum, sorry if there is a duplication) Anyway, I have a brand new Onan flat 20 hp engine in a Toro Groundsmaster that will not pull a load when hot. Starts great, runs great for about 40 minutes, then bogs down, backfires and gives up. Will restart immediately, but won't take a load. I've checked valve clearance, compression, manifold vacuum, put on a gravity fuel system, everything seems OK. The only clue is it seems to be heat related, otherwise I am stumped. Any thoughts?
Bushogpapa
02-02-2005 18:46:44
 Re: Onan loses power in reply to Jack at LL, 02-02-2005 13:33:42
Have you ever checked the valve clearances..??
Change the plugs, and when it is running, place your hand over the air-inlet to the carb (partially), and see if it "picks up power" or "picks up the load" better..if so, it is running lean.. Those mixture screw settings are pretty narrow in latitude..have to be set just right.. There could be a bit of dirt laying in the power needle cavity..causing a lean condition at times..
Ron..
Everett
02-02-2005 17:17:29
Had one that did that---over heated and lost power, found mouse nest pluging cooling fins. Everett
old
02-02-2005 14:50:14
May have a problem in the ignition system, bad coil in the mag if it has one or maybe even getting a vapor lock in the fuel system
UncleTom
02-02-2005 18:19:09
 Re: Onan loses power in reply to old, 02-02-2005 14:50:14
Ignition module
