Tractor Talk Discussion Forum
Help Hydraulic Leak
TomTX
02-04-2005 09:33:50
My 1983 MF-690 recently started leaking hyd fluid from the 2-spool auxiliary hydraulic valve, used to power twin remotes. Tractor is cab model and it took some doing with a mirror to find the exact site of the 2 leaks. With tractor running it leaks at a fast drip from each of 2 poppets on the underside of the two-spool valve assembly. Anyone run into this problem. What is causing the leaks from these "poppet" things? Thanks in advance for your help. Tom
Joel Harman
02-04-2005 09:35:55
 Re: Help Hydraulic Leak in reply to TomTX, 02-04-2005 09:33:50
Not a hydraulics guy but best WAG. bad "O" rings.
