Tractor Talk Discussion Forum
Info on Hydraulics
Keith-OR
02-04-2005 22:16:08
Manual calls for a hydraulic "snubber" between pressure Gauge and pump when testing hydraulic system pressure. What the Heck is a Hydraulic Snubber?....Thanks Keith
Thanks !!!!!
02-05-2005 10:31:34
 Re: Info on Hydraulics in reply to Keith-OR, 02-04-2005 22:16:08
Thanks Bob and M Redneck. learned what a snubber was and what its purpose is. I have a oil filled 2000 psi gauge, will use it and no Snubber. Will post results....Keith
Midwest redneck
02-05-2005 06:57:56
When I used to build hydraulic systems I used a small shutoff valve in front of the gage and then just crack the valve open to get a pressure reading.
Bob
02-05-2005 00:11:29
It's a restrictor, or similar device that dampens pressure pulsations produced by the system so the gauge will not be damaged, and/or and accurate reading can be made, without the gauge needle fluttering so badly that an accurate reading cannot be obtained.
