Tractor Talk Discussion Forum
Rubber hose for antifreeze
UncleTom
02-06-2005 09:27:31
Hello there, I have replaced a small piece of 3\8 rubber hose on my truck radiator where the return comes for the throttle body coolant. All i could get at the parts house was some 4oo psi. transmisson hose made for oil. Is this sutible for anti-freeze? Thanks in advance
John M
02-06-2005 12:15:02
 Re: Rubber hose for antifreeze in reply to UncleTom, 02-06-2005 09:27:31
If that doesnt work out and you cant find what you need,let me know.I have a guy whoi sells 3/8 heater hose for that type of thing.Its made by Gates I think.I used it on something I had awhile back for the same thing.
bo
02-06-2005 11:15:20
sure. What is "return from the throttle body coolant"?
UncleTom
02-06-2005 11:40:19
 Re: Rubber hose for antifreeze in reply to bo, 02-06-2005 11:15:20
My 93 dorf has a throttle body with a 3\8 hose running to it from the block to warm it up and keep it from frosting up in cold weather. It dumps it back into the radiator by a steel line and then a short hose from the steel line to the radiator tank. I just didnt know if the rubber was compatible with antifreeze. I would think that if it can take oil it could take antifreeze. Some hoses are fussy on what you put in them such as fuel,etc. UncleTom
bo
02-06-2005 12:06:33
 Re: Rubber hose for antifreeze in reply to UncleTom, 02-06-2005 11:40:19
Learn somthing new every day. I had a throttle body once....that's why I asked..there was no hose on that one. The hose will be fine.
Kelvin
02-06-2005 11:38:27
Some Throttle body fuel injections (I saw them on Buicks and Oldsmobiles in the mid 80's) had their own coolant supply to one side of the throttle body. I guess the coolant kept the throttle body at a constant temperature when warm and therefore should have been easier for the computer to calculate the proper mix.
I would think that the antifreeze mix wouldn't be nearly as rough on a hose as hot oil.
UncleTom
02-06-2005 13:19:13
 Re: Rubber hose for antifreeze in reply to Kelvin, 02-06-2005 11:38:27
Well it is a 5.8 with port injection but what i call the throttle body is the part with the butterflys in it. I recently put water pump in it and recrimped all the little tabs around the plastic tanks. It was leaking around the tanks. I have fixed atleast 5 radiators that way. I just use a vicegrip and tension those tabs a little bit. Works good. But that little hose i was talking about was leaking a bit after i was all done. Dry as a bone now.
T_Bone
02-06-2005 13:59:47
 Re: Rubber hose for antifreeze in reply to UncleTom, 02-06-2005 13:19:13
Hi Tom,
Fuel line is made from Nitrel and anti-freeze hose from rubber.
You can't use rubber for fuel line but you can use Nitrel for antifreeze or most other chemicals.
T_Bone
UncleTom
02-06-2005 17:46:15
 Re: Rubber hose for antifreeze in reply to T_Bone, 02-06-2005 13:59:47
Thanks guys for all your replys, that is how i learn is by asking questions. Ive always said a stupid question is better that a stupid mistake.
paul
02-07-2005 12:43:09
 Re: Rubber hose for antifreeze in reply to UncleTom, 02-06-2005 17:46:15
You got that right on all counts. :)
--->Paul
