Tractor Talk Discussion Forum
NF with loader
Duane E
02-07-2005 19:25:06
You know, I get very uneasy whenever I see a narrow front tractor with a loader on it. Yet I see a lot of them. Are they safer than it looks????
What are your thoughts????
David B
02-08-2005 22:06:54
 Re: NF with loader in reply to Duane E, 02-07-2005 19:25:06
I haven't run a NF with a loader, but I would think on older tractors with no power steering it'd be easier than a wide front.
I'd also think you might turn a little shorter.
Like I said, I haven't used one. Only used a loader on a 7700 and 7810 John Deere.
JK-NY
02-08-2005 16:37:00
I agree with the others as far as stability a wfe is a little more stable than a nfe, loader or no loader, but not as much as you think. If you are using a loader to near full lift height and its too unstable for a nfe tractor it would also be unsafe with a wfe. The biggest drawbacks to nfe loader tractor would be hard steering in soft ground without p/s and the usual nfe problems in muddy ground or deep snow of pushing mud/snow with the front wheels and getting stuck much easier than a similar wfe tractor.When it comes to loader safety the name of the game is keep the center of gravity as low as possible.
thurlow
02-08-2005 08:29:30
Have you read the posts below? Can you tell the "users" from the "theorists"????? ?
Dave 2n
02-08-2005 18:49:23
 Re: NF with loader in reply to thurlow, 02-08-2005 08:29:30
Excellent point about "users" and "theorists"!
I've about given up getting involved in this type of discussion but here I go, one more time: from 1948 through 1964, we used a Farmall M NF and International loader to clean a very large heifer barn and also to load creek gravel for maintaining farm roads. Never once, not even ONCE, did we have a bit of trouble!
Allan in NE
02-09-2005 02:21:29
 Re: NF with loader in reply to Dave 2n, 02-08-2005 18:49:23
Mornin',
This one musta worked okay; still all in one piece. :>)
Allan
third party image
Mike M
02-08-2005 07:41:38
One of the most stable loader tractors I have owned was a JD 50 with a NF and a # 45 loader. With a 2 cyl. tractor 70% of the weight is on the rear and 30% on the front balancing them very well with very little added weight needed. My worst was an industrial JD 500 with a loader. Like a 3020 with a very heavy wide front end.You could hardly hang enough weight on the back to make it stable.Let me tell you that the rear end will come up way too far before you get close to the front end piviot stop,this is enough to scare the heck out of ya. Got a gas 4020 with a 158 loader and wide front end now.Have the rear tires loaded and hang a model 115 blade on the rear 3 pt. and put on chains for the winter.This makes a very useful and stable outfit.
RayP(MI)
02-08-2005 14:35:48
 Re: NF with loader in reply to Mike M, 02-08-2005 07:41:38
My uncle had a JD 50 NF with a Deere loader, Moved tons of manure with that thing over the years. No problem. We have a JD B NF with a New Idea-Horn that reaches awfully high. Never had that one so's it acted unstable. Used it a lot on very heavy rocks - just didn't lift 'em very high! As with any machine, user MUST use all due caution. Never thought either tractor was unstable, however.
the tractor vet
02-08-2005 07:31:32
I had a IH 2000 on a 706 narrow ft. for years and loaded lots of equipment with it cleaned barn loaded slag and stone old junk cars my only fear was breaken the spindel but never did but on my buddys 706 wide ft. now we broke the ft somany times i quiet counting , how would you like to have a 15ft. culimulcher 8 ft. off the ground and the wide ft. breaks, that will put big time racing strips in your shorts.
Allan in NE
02-08-2005 06:33:18
Mornin' Duane,
I'm the same way. I think a narrow front tractor under a loader is as safe as a wide front as long as the head is kept low.
But when you are dealing with loading a feed wagon, stacking bales or what ever with that head up in the air, the wide front just gives the thing more of a sure-footed "stance" to my way of thinking. Dunno.
Allan
third party image
paul
02-07-2005 22:54:50
If you think about it, what does wide front get you? There is still a pivot point on the front axle, so the tractor will tip all the same. Wide front is only marginally more stable.
It's all about ballist, you need the rear axle weighted down to the ground. My long wheelbase IHC H narrow front with 900# on the rear axle & hitch is more stable than the short wheelbase compact tractor with wide front that I got. I have to think when using the compact loader, even after I filled the tires, compared to the H with narrow front & loader.
--->Paul
MeAnthony
02-08-2005 06:44:34
 Re: NF with loader in reply to paul, 02-07-2005 22:54:50
Doesn't the wide front also have a stop built in to the pivot, so it will only move a pre-determined distance, bringing the weight to bear on the axle tube? Then you'd have the stability of the downhill side tire being spaced away from the center of the tractor? I'm not trying to be a wise guy, just want to make sure I have the correct understanding of it myself.
paul
02-08-2005 12:59:37
 Re: NF with loader in reply to MeAnthony, 02-08-2005 06:44:34
Some do - my compact likely does - some don't. My IHC 300 & Ford with Schwartz wide front have no actual stop - eventually the tube will hit something, but not for a long ways. The Ollie wide fronts don't look like there is any special stop.
The problem is, once you are leaning enough to hit the stop, you are in some trouble already. For me, my narrow front H would lose traction before it would lean itself over. My wide front compact 4wd tractor will lean over, & continue to move because of the 4wd - this can really get me in trouble if I am on a hill, and it continues to drive me into a worse condition....
You are technically corret. And yes a wide front is a bit more stable. But, only a bit.
In the real world, I can make a long-wheelbase old narrow front tractor _much_ more stable than a wide front from the dealer.... It's all about getting the weight right, and using common sense (some of which must be learned...). Wide or narrow front is really the least important factor in this.
I feel if you hit the stop on the front axle, you have already lost - you were not set up properly and are trying to wreck. Your condition is only valid for lifting a load from the ground that is too heavy. In that case, the front wheel stop may help you if the bucket is still low enough to be in contact with the ground. Once you have a load in the bucket & raised, if you hit a slope that tilts your rear end up, the stop will _not_ stop you - you are going to go over. You have passed critical mass by then.
And you are not being a wise guy - good discussion. :) To me your question is sort of like a crosswalk in the street - you might legally have a right to be in the crosswalk, but if you step out in front of the 4000# car, it's only a technicality - you still will be dead. :) :) The front axle stop does more harm by giving people a false sense of security, instead of properly setting up their tractor for a loader.
We go through this discussion several times over at the tractorbynet.com compact tractor site - new owners don't want to ruin their lawn by adding ballist to their loader/ lawn mower tractor, and then talk about all the times a rear wheel lifted on them - or that they have only rolled it 2 times so far..... These same people talk about how dangerous a narrow front tractor is, can't see how those were even legal ever... I can only shake my head.
--->Paul
Kelly C
02-08-2005 15:34:33
 Re: NF with loader in reply to paul, 02-08-2005 12:59:37
third party image
I like my H narrow, works great.
But I do know that the front will dig its self in the mud so fast its not funny.
Not that I have any particular problem getting any of my tractors stuck :-)
Wonder what my H would look like with a pair of ballon tires on the front?
paul
02-08-2005 15:54:03
 Re: NF with loader in reply to Kelly C, 02-08-2005 15:34:33
Yours is cut down (steel wheels)! Mine is original rubber rims, but must have been near the first ones on rubber with the war years....
I also have the original IHC loader on mine, what brand is yours?
Original paint on mine too, where you can find any....
Mine is very very tired, lift gets real slow when the oil warms (single acting belly pump), & the last set of rings dad put in were too little too late. But it still gets some manure in the spreader. :) Real fun to run without live pto or power steering. :)
Kinda actually would want to get rid of it, but not worth anything in this shape, and as it was I think dad's first new tractor I guess I won't part with it.
--->Paul
RustyFarmall
02-08-2005 07:37:53
Yes, the wide front does have built in stops. The problem is that by the time the tractor frame hits those stops you are already leaning so much that the whole outfit is probably going to roll anyhow. Don"t get me wrong, I do believe that the wide front does add more stability, but not as much as you might think.
Harley
02-08-2005 09:14:16
 Re: NF with loader in reply to RustyFarmall, 02-08-2005 07:37:53
Hi Rusty. You are absolutely right. A wide front end is No more stable than a narrow one, but is gives one the sense of stability because it is out there on each side. Down here in the Ozarks, we have some hills you couldn't walk up let alone opperate a tractor with a loader, so it wouldn't matter what kind you had on the front, but like you said, it all goes back to the operater. I've had both, and like others have said, by the time the stops hit on the wide front, it is already too late, cause the back end is already off the ground, and the pucker factor is at about an 8. Common sense, enough weight on the back to offset the load on the front, and another dose of common sense will make all the difference. Even with a lot of weight on the back if a guy picks up a big load, then goes across the side of an incline, gravity is GOING to take over. Always operate up and down on an incline and turn at the top or bottom of said incline and one should be alright. Later, Harley
big jt
02-08-2005 07:36:32
Morning Tony
You are right about the stops. Only problem is on some of the aftermarket WF's the stops will allow the tractor to lean to the point of no return.
Running a loader with a NF has never really bothered me. Right now I don't have one but wouldn't be worried about it either.
MOST IMPORTANT IS TO USE THE GOOD JUDGEMENT THE GOOD LORD GAVE US. Not doing that is usually what gets people in more trouble than how your rig is equipped.
JM2CW
jt
Allan in NE
02-08-2005 06:55:35
Hi Tony,
Stop or no stop, it doesn't matter.
At the end of the day, the tractors weight is still setting on those tires no matter where they are located; underneith the tractor or out in a wide stance.
My view,
Allan
RustyFarmall
02-07-2005 19:53:48
Narrow front, wide front, take your choice. Neither one is any safer than the man who is operating it. Common sense and experience will make just about anything safe. A carefree, reckless attitude will be an accident just waiting to happen.
Red Dave
02-08-2005 07:36:06
 Re: NF with loader in reply to RustyFarmall, 02-07-2005 19:53:48
Exactly right Rusty!
How much empty space there is between the operators ears is every bit as important as how much space there is between the front tires.
RustyFarmall
02-08-2005 07:40:02
 Re: NF with loader in reply to Red Dave, 02-08-2005 07:36:06
Red Dave, that is a very good way to explain it. Even I can understand that one.
steveormary
02-08-2005 10:35:27
 Re: NF with loader in reply to RustyFarmall, 02-08-2005 07:40:02
I have run both with no problem. NF will sometimes ball up in soft manure . Like trying to put a round bale in a bale feeder. My preference would be wide front.
steveormary
paul
02-08-2005 13:22:36
 Re: NF with loader in reply to steveormary, 02-08-2005 10:35:27
There is a good point. A wide front will sure give more control.
--->Paul
