Tractor Talk Discussion Forum
John Deere 14T Baler
Louie77
02-08-2005 18:57:05
I have a John Deere 14T baler that has been sitting for 15 years or so. It worked perfect before it set. I am sure it needs some maintance before it works. My Question is, What is it worth???? As is and in working order.
Kelly C
02-10-2005 17:17:46
 Re: John Deere 14T Baler in reply to Louie77, 02-08-2005 18:57:05
Depends where you are at. If its around here in central ,MN where they still use a small baler.
Its worth $500 just becsuse its green.
RayP(MI)
02-09-2005 17:28:44
Wife bought a NH 268 Hayliner, scruffy but very workable, for $750 - last fall. Good working baler. Put up 2500 bales with it this last summer. Ended up replacing two cheap bearings, couple pickup teeth, and a tire. Suspect that old balers are pretty much the same as far as price. We used a 14T for many years when I was growing up here on the farm. Contrary to what some may say, it was a good baler.
Rauville
02-09-2005 08:19:30
A fellow is advertising a 14T that has been shedded on the local "Farmer's Market" for $200...sounds reasonable.
txblu
02-09-2005 05:01:14
Bought a 24T (upgrade to 14T) several years ago for $700. Had been barn kept and owner wasn't afraid to use his grease gun. Only thing I did was replace the tieing brake shoes ($40) and it did fine.
I'd say put what you want on it. If it sits, drop down till it sells or keep it.
Mark
old
02-08-2005 20:46:23
Well you can say as is but can't say in working order unless you go out and make sure it does work. The last one I got which was field ready cost me $350
