Tractor Talk Discussion Forum
hydraulic help
Dave Null
02-09-2005 03:18:48
Hi Folks,
I was wondering if someone could point me in the right direction. I'll try to make a long story as short as possible. I've got a '64 Mccormick D326. It was made and sold in Germany so I'm not quite sure what the American comparison would be (3 cyl diesel, 26 HP). Says McCormick on the trim, but when I go to the parts store, the books that the guy uses all say Farmall. I bought the tractor for use around the place and decided to put a front loader on it. Here goes: I bought a frontloader and am ready to hook up the hydraulics. My tractor has internal hydraulic controls (just have the two levers on the outside). The tractor that I got the front loader from was a "61 or '62 model (I believe a D322 or D324)with external hydraulics ( 3 seperate controls connected by steel tubing) two are the same except for one has a dial on the lever hub (I think to keep the hydraulics from sinking when the tractor is not running??) They are about 4 inch cubes with 5 numbered openings (1,2,and 3 are in the lower front and 4 and 5 are on the upper back side) 1-3 has arrows molded into the case 1=in, #2 and #3=out (1 and 2 are side by side and #3 centered above them). The 3rd is quite a bit smaller and simpler. 2 1"x2" boxes side by side with a shaft (with control lever) connecting them in the middle (whole thing is 2"x4" and an inch thick with 2 front connections and 2 on the back). There is a connection on both ends of each. The 2 on the back are connected by a "Y" shaped tubing and the inside front one has a tubing conected to it. I need to make one of these work as the hydraulic control for my frontloader. Can someone explain how to make the connections. I've never fooled much with tractors or hydraulics. I had a fool proof plan that was unintentionally sabotaged. I had to make two trips to get the frontloader I bought. On the 1st one I picked up all except hydraulics. On the next trip to pick up the hydraulics, I had a camera and notebook so I could make me a dummy proof plan for hooking everything up. When I got there, the guy had sold the tractor. He was generious enough to remove all of the hydraulic controls for me, which was real neighborly. But now I'm pulling out my hair over something that is probably simple to you folks. Any help would be appreciated. Thanks, Dave Null PS. I believe the smaller of the 3 valves is just a 3 way valve and doesn't work on the same principal as the other 2.
Dave Null
02-10-2005 02:24:36
 Re: hydraulic help in reply to Dave Null, 02-09-2005 03:18:48
Thanks for the answers (both of you). Most folks over here don't have the "fix it" mentality. If it's broke take it to the shop and put on new parts. Doing something from scratch is next to unheard of. Garages in general and land machine shops especially are pretty proud of their work and parts here. That along with the language barrier makes it hard to go to them for help. My neighbor has a guy coming by this evening to look at it. If he can't help me, I'll give all the details tomorrow.
Thanks again, Dave
J. Schwiebert
02-09-2005 18:34:35
Here is another though. I do not know what you are planning on doing with the loader, but I would suggest finding the port that has pressure and running that to a seperate valve that has one spool with a float spool. Then run the other line either in a return port or back in the reservoir. Questions?
I would also like to talk to the midwest redneck. Thanks.
Midwest redneck
02-09-2005 16:05:55
I am trying to see what you need, your post was quite long. To hook up hydraulics for a FEL, I have never had to work on tractor hydraulics. The numbered port you are describing are as follows: (I think they are....#1, pressure port, #2-#3 are return (or tank ports) and the #4 and #5 ports are the cylinder ports. I think that to have a front end loader you will need two valves, one for the lift and one for the tilt of the bucket. Like I said I never worked on tractor hydraulics, mostly machines in industry. Post again if you need more info.
