Tractor Talk Discussion Forum
what do i do now???????
vabill
02-09-2005 20:35:35
i have the case 385 with lots of problems. it stopped while i was warming it up. wouldnt restart. ihad the starter selonid changed, still wouldnt start . i drained the crankcase,(grey slime came out). the flywheel moved when i pushed it with a screwdriver. what should i do now? put oil in & try to start it, pull the head? thaks for all the excellent help up to now. bill
msb
02-10-2005 08:26:25
 Gray slime?? in reply to vabill, 02-09-2005 20:35:35
How much gray slime? Did you check the radiator coolant level? Sounds like you have coolant in the oil.
scratching head
02-10-2005 05:50:35
 Re: what do i do now??????? in reply to vabill, 02-09-2005 20:35:35
ok,lack of fuel, diesel/gas? take head off. pull number two piston it aint working anyway, so oil pump can come up. put back to gether and pull or push to shed to get started. ok
