Tractor Talk Discussion Forum
Inexpensive Box Blades on Ebay
SkyHarborCowboyJoe
02-10-2005 22:48:00
Has anyone bought one of these units? They are so inexpensive and for the sandy soil I have would probably hold up. Just wanting your opinions as used ones are hard to find in AZ anyway.
Joe
PS> I may just make my own if I have to but at their prices (IF they are US made, wont buy a foriegn one) my time might be worth more.
john_bud
02-11-2005 06:59:26
 Re: Inexpensive Box Blades on Ebay in reply to SkyHarborCowboyJoe, 02-10-2005 22:48:00
Sky,
The deal with box blades is that weight is needed for them to do a good (or even decent) job. You might be able to buy one cheap and then weld on 7-800 pounds of steel and make it work, but at that weight, it will probably fail. The 3 point setup is pretty cheezy on them. It"s up to you, but you do get what you pay for.
Rule of thumb -> 20-30 pounds of implement weight per tractor Hp for ground engaging implements.
My box blade is a Gannon Landscaper LB120 (IIRC) that is 66" wide, has retractable scarifiers and weighs about 900#. I don"t worry about hitting a root or a rock...
Let us know what you do and how it works out!
Cheers,
jb
Bus Driver
02-11-2005 05:50:23
Be sure to add the transportation cost for any eBay purchase. Local prices may then look better for implements.
