Tractor Talk Discussion Forum
Trailer brakes
Swede
02-13-2005 09:00:21
I need to put a brake controller in a 2000 Chevy Silverado. What kind of electric brake controller are people using. Thanks..
dennis in nc
02-14-2005 05:27:31
 Re: Trailer brakes in reply to Swede, 02-13-2005 09:00:21
whats under the hood of that 2000
swede
02-14-2005 11:26:25
 Re: Trailer brakes in reply to dennis in nc, 02-14-2005 05:27:31
5.3 vortec It pulls what I want with plenty power. 16'with 2' beavertail. Just need to hook up the brakes.
BFO
02-13-2005 16:17:12
Tekonsha Prodigy, probably the best on the market.
John M
02-13-2005 11:18:22
Tekonsha Voyager.Simple!
Can't even use my name
02-13-2005 10:33:55
I have a Reese and love it. It is digital so you can easily go back to the setting you were at either empty or loaded. And it has the ability change the time from you stepping on the brakes till it is at the power it is set at, a lot less jerking around.
evielboweviel
02-13-2005 11:09:55
 Re: Trailer brakes in reply to Can't even use my name, 02-13-2005 10:33:55
I had a Reese controller and took it off. I now run a Voyager like it much better. The Reese was too slow too fast always needing adjusted depending on load. The voyager acts based on how fast you are stopping and works much better, esp in a panic stop or a slow stopping stituation. Basicly the same money to buy.
I would check in the glovebox and see iof you have the wireing harness for the controller. if not then get one off of chevy dealer.
Good luck
Ron
02-14-2005 05:03:55
 Re: Trailer brakes in reply to evielboweviel, 02-13-2005 11:09:55
I had an older Tekonsha but got this new Reese for $20! I don't pull too often so for the money I don't think I can complain. I do beleive the Prodigy is probably the best there is though.
