Tractor Talk Discussion Forum
Massey Fergerson 235 disel 3 cyl
PHILLIP RUTLAND
02-13-2005 11:51:47
is smoking and missing I have put new injectors in and still having the problem. any suggestions what my problem would be now.
RAB
02-13-2005 14:33:24
 Re: Massey Fergerson 235 disel 3 cyl in reply to PHILLIP RUTLAND, 02-13-2005 11:51:47
Check compression. Change injectors around and find if it is a cylinder or injector. Black smoke or blue?
Presumably OK before problem developed?
Could be anything from a bad injector, valve, piston, rings, bore, gasket to a few others.
Sounds like you probably wasted your money on injectors, if problem is still there and still the same.
Diagnosis of symptoms is the way to go before wasting any more dosh.
Regards, RAB
