Tractor Talk Discussion Forum
Procrastination? Who? Me?
Allan in NE
02-13-2005 12:05:39
Hmmmm,
I've got to rebuild this old grapple fork and the wife keeps telling me that I'm procrastinating.
Gee, can't imagine why. Groan….. :>(
Allan
third party image
JDB
02-14-2005 10:37:43
 Re: Procrastination? Who? Me? in reply to Allan in NE, 02-13-2005 12:05:39
Hey Allen,
That one looks good compared to the one my father still uses
Leroy
02-13-2005 21:54:24
What would it have been built for orignaly? You have so much stuff never heard of in Ohio.
Allan in NE
02-14-2005 03:27:27
 Re: Procrastination? Who? Me? in reply to Leroy, 02-13-2005 21:54:24
Hi Leroy,
They are something of a combination head which starts out as a simple old materials handling fork.
Add that pan across the lower teeth and it can be used to move dirt. Then, add the grapple fork and it is used for hay, straw, bales or whatever.
The head is very common out here because of the cattle. With the dirt pan off, they work real slick at feeding silage and hay at the same time.
Anything hauled into the lot in the form of feed over winter has to be of course, hauled out in the spring in the form of manure, so the darned things pretty much stay on the loader all the time except for snow removal and stacking hay which would use either a bucket or a hay head (Sweep).
Allan
caseyc
02-13-2005 20:38:27
i have one that looks just like that... well maybe not... all the teeth are straight! i'll sell it to ya! maybe even throw a '66 into the deal? what's it worth to ya? it works great for feeding hay to horses!
casey in SD
Dug
02-13-2005 18:10:33
Hey Allan,
Something else I was thinking about trying with the grapple. Could a guy rig a wedge on the middle "prong" and use it as a wood splitter? You could remove the three teeth, then put the wedge in place of the middle tooth. What are the pitfalls versus the rewards? Think it would work?
Dug
Dug
02-13-2005 18:03:14
I understand your quandry, Allan. I have one just like it, of course mine is a snaggle tooth looking beast compared to yours. I pulled the stunt steveormary was talking about and tried pulling old hedge limbs out of the trees. Really bends those teefers. I took mine over to a buddies shop two weeks ago and keep "postponing" going over to work on it. Of course it's been so wet I couldn't use it now anyway. But they sure do come in handy. I've cleared at least 50 trees with it, hedge, cedar and thorn locust. Don't know how I ever got along without it.
Since I've got ear, I might ask how are you going to brace those teeth? Looks like you've got some bracing on it now. I was thinking about running a piece of angle across the three teeth in three different places (about 18 inches from each other.) I'm afraid, though, it may cause me to hang up when unloading brush. Any good suggestions to beef it up and keep it from grabbing brush when unloading?
Dug
Allan in NE
02-14-2005 03:49:26
 Re: Procrastination? Who? Me? in reply to Dug, 02-13-2005 18:03:14
Hi Dug,
The problem with these earlier ones was that the forks were only what? Only 3/8" thick and made of steel, I think. They would bend. The replacements are 1/2" cast iron teeth; they don"t bend, they just snap off if overloaded.
So anyway, what happens with these old ones is that they would bend and the first tool that some old farmer grabbed was the darned welder, tryin" to "brace" the teeth. That just doesn"t work and is what I"m faced with; getting all that old badly welded crap off of the head.
The best way to strengthen the things is to use the factory Farmhand reinforcement, which is nothing more than an angle iron laid crosswise across the top of the forks out where they start the bend downward. Then two smaller angle irons were welded perpendicular to the first iron and straddled each fork tooth with a bolt thru the two irons under the fork.
That way, nothing is actually welded to the fork itself.
Allan
RJ-AZ
02-13-2005 16:18:41
Hey that grapple don't look all that bad!!
Looks prtty normal for an old Farmhand F11 loader. In fact my brother would call that one pretty cherry.
Allan in NE
02-14-2005 04:15:25
 Re: Procrastination? Who? Me? in reply to RJ-AZ, 02-13-2005 16:18:41
Mornin RJ,
Aw, the pictures don't really show how bad this thing is. Welds and "farmer fixes" all over the place. She's a tired one.
Allan
Oldjohn
02-13-2005 12:29:16
Is it for loading horse hay? ;}
Allan in NE
02-13-2005 13:22:52
 Re: Procrastination? Who? Me? in reply to Oldjohn, 02-13-2005 12:29:16
Second thought,
Don't think it is worth saving; needs one fork, one outter tooth & clamp, the pivot shaft assembly and one pillow block.
Might be able make a big bale fork outta it though. Dunno. :>(
Allan
third party image
steveormary
02-13-2005 17:50:33
 Re: Procrastination? Who? Me? in reply to Allan in NE, 02-13-2005 13:22:52
You was trimming trees with it? They get that way if you try to pull dead branches out of a tree. Right? And dont ask how I know.
Too many rains here. farmers cant get their onions,cabbage and lettuce planted yet.
steveormary
