Tractor Talk Discussion Forum
Sears garden tractor
Bigmonts
02-13-2005 19:52:58
Does anyone know anything about an old yellow sears suburban ss16 with a tecumseh engine? Anything you could tell me would be appreciated.
83Jim
02-15-2005 05:10:40
 Re: Sears garden tractor in reply to Bigmonts, 02-13-2005 19:52:58
I have a 1973 Sears ST-16 garden tractor with 16 hp Tecumseh. Maybe I can help.
What do you need to know?
bigmonts
02-15-2005 09:01:45
 Re: Sears garden tractor in reply to 83Jim, 02-15-2005 05:10:40
I was wanting to know about what years they made them, if they are pretty good tractors, about what one is worth and how big they are. Thank You for your reply.
83Jim
02-16-2005 05:17:11
 Re: Sears garden tractor in reply to bigmonts, 02-15-2005 09:01:45
Not sure of the years they were built. Mine was bought new by a friend's father in 1973.
I have had problems with the electronic ignition system on mine. This must have been "state of the art" in 1973 but to replace the ignition (spark)module is about $100 and the stator (alternator) which fits under the flywheel is about $200. The rectifier (regulator) for the alternator is another $100.
A running unit in good condition would be worth about $400-$500 just for the items listed above. Alternatively, you could be looking at that much or maybe more (with labor) to get a unit running if there is a problem with the ignition system.
The overhead valve engine designs are prone to leak oil from the seals around the valve push rod tubes. However, this is a fairly simple fix but does require removing the head and replacing inexpensive O-rings on each end of the tubes.
These units weigh about #250. They have lots of power and good heavy transmissions. (Three speeds forward plus reverse. (Hi-Lo range gives 6 speeds and 2 reverse).
bigmonts
02-16-2005 08:03:40
 Re: Sears garden tractor in reply to 83Jim, 02-16-2005 05:17:11
Thank you for your input it is very helpful.
