Tractor Talk Discussion Forum
9N PTO Drive
Joe in VA
02-14-2005 06:58:41
I have a '39 Ford 9N. Went to sow some grass seed this weekend with a new PTO driven spreader, only to find that the drive shaft that came with the spreader was too long. Do these older Fords need shorter PTO drive shafts of do I need to look into getting longer lift arms - assuming they are available ?
Tramway guy
02-15-2005 07:48:00
 Re: 9N PTO Drive in reply to Joe in VA, 02-14-2005 06:58:41
Maybe you have an adaptor or overrunning clutch on the PTO shaft that makes the tractor shaft too long. There are adaptors that resemble a bushing and might make it work without cutting the shaft.
Pitch
02-14-2005 07:13:45
You have to cut the shaft. That will be hard going but no other way. Measure it so it does'nt bind when fully elevated and then lower it and make sure it doesn't seperate when extended. Take half off of each section. file the burrs off and chamfer each end slightly grease it up and your ready to go.
Joe in VA
02-14-2005 07:34:08
 Re: 9N PTO Drive in reply to Pitch, 02-14-2005 07:13:45
Will I be able to use the same shaft with other equipment, or do I need to cut the shaft for each new impliment I buy?
paul
02-14-2005 10:39:20
 Re: 9N PTO Drive in reply to Joe in VA, 02-14-2005 07:34:08
That is a hit or miss question. :)
Most tractors are more or less the same dimentions, but for example if I use the same implement on a cat 2 & cat 1 tractor one needs to be careful. Generally a longer pto shaft will give you more leeway, some of those really close-in 3pt implements are a pain, as the pto needs to be so critically short.
It is typical for new implements to need some trimmimg tho. They are sold with a standard pto that probably will work on cat 2 tractors, & you trim to length. Often you can order them with a longer or shorter pto; however the dealer finds it easier to order all with 'long' and then trim to fit.
--->Paul
