Tractor Talk Discussion Forum
1928 Cat 22
troy in Wa
02-14-2005 14:02:58
My Mag gets spark when it's off and I spin it fast,but when I put it on there's no spark,my gap is at .015 amd I cleaned all of my contact points
Mike M
02-14-2005 16:14:33
 Re: 1928 Cat 22 in reply to troy in Wa, 02-14-2005 14:02:58
What kind of mag is it ? Most all mags have somekind of an impulse coupling that is spring loaded so it turns the rotor fast during hand starting and then once started weights move a pawl out of the way so it doesn"t impulse anymore and this also changes the timing from starting to running. Almost sounds like yours isn"t impulsing/springing like it should.
Glen in TX
02-14-2005 16:13:35
The impulse trip spring in the drive end may be broke or the impulse just sticking. Pour some oil and penetrating fluid in the impulse end to loosen things up. What kind of mag is it?
Troyr
02-14-2005 17:59:55
 Re: 1928 Cat 22 in reply to Glen in TX, 02-14-2005 16:13:35
My mag is an Eiseman j-4, my spelling is wrong.
Glen in TX
02-14-2005 20:48:41
 Re: 1928 Cat 22 in reply to Troyr, 02-14-2005 17:59:55
My books show your Cat 22 originally using a Eisemann GV-4 mag. It's probably that or another GL or other G series. I may have some parts for that one yet but not much. See if you can get the impulse loosed up or if it is tripping at all then on wind up.
