Tractor Talk Discussion Forum
starter rotation
37 chief
02-16-2005 01:06:11
A friend of mine has a starter that fits his AC Model M, but it turns the wrong direction. Can the rotation be changed on a starter? Stan
JHesler
02-16-2005 07:43:42
 Re: starter rotation in reply to 37 chief, 02-16-2005 01:06:11
Flip the field polarity with respect to the armature. Either swap the two field wires or the two armature (brush) wires. Whichever is easier. But if it's a Bendix drive as stated before, you still have a problem.
bill b va
02-16-2005 06:45:36
yes
Jon H
02-16-2005 06:20:31
You should be able to find a starter armature and drive set up for the opposite rotation. It will take a different armature because as Bob pointed out,the drive overunning clutch must also be set up for the opposite rotation. Many times the splines that turn the drive are angled differently on the armature,so you cannot just reverse the field/brush connections to reverse the starter .
Bob
02-16-2005 01:40:25
If you did manage to change the rotation electrically, you'd still need to replace the starter drive ("Bendix") with one designed for the opposite rotation.
