Tractor Talk Discussion Forum
Cub Help
David Moore
02-16-2005 15:42:09
O.k here is the story I have a 1962 farmall cub totally restored looks and runs great BUT it seems as if It has no power it starts and runs like a sewing machine but when I put it in 2 or 3 gear it boggs down and about dies it does it in 3rd worse than second and I hooked my l-22 mower to it the other day and I started out and it about died but it didnt I was just curious it had sit for about 11 years and I pulled it out of the weeds and replaced the plugs plug wires and put new points and condenser on it and we pulled it with my other tractor and it fired right up but then you would have to run it 1/2 way choked so we bought a new zenith carb for it and it started easier than before and it has more power than it did but still not enough I wish you all could help me with this problem this cub was purchased new it 1062 by my great great grandpa and it really means alot to me I just wish it ran as good as it looks so any help would br greatly appreciated
Thanks David Moore
David Moore
02-17-2005 05:26:11
 Re: Cub Help in reply to David Moore, 02-16-2005 15:42:09
third party image
the gas line seems to be a little kinked but why didnt it have power with the old carb and the governor it working properly you can through the throttle all the way up and it will kick all the way back and level out but the gas line is kinked its not line its copper piped I think that is the problem also when I run it full throttle and let off the clutch it will make back fire like its not gettin enough gas so I think the gas line is my problem
Thinks for all your help Oh here is a pic of it
wdtom
02-16-2005 18:36:10
Is it running too lean, or is the timming off?
farmalljim10
02-16-2005 16:13:38
Check the air cleaner. could also be you have to set the main mettering jet.That should be 1 1/2 turns out .. = or - 1/4 turn. check gas line also..
