Tractor Talk Discussion Forum
Industrial tractors
37 chief
02-19-2005 21:55:21
I have a MF 203, which I think is a industrial type tractor. I use it to pull a 6 ft. Woods mower. I just acquired a JD 401 B,(with a three point hookup, and a PTO) which is also a industrial type rtactor.What is the difference between these tractors over the ones used for farming? I have put a lot of hours on my 203, and does a fine job. Stan
cockshuttguy
02-21-2005 13:54:38
 Re: Industrial tractors in reply to 37 chief, 02-19-2005 21:55:21
I have a MF 30 Industrial. Compared to a regular the industrial is build like a tank, weighs like a tank and when it gets stuck you need a tank.
The front end is especially heavy duty. Overall I think they were designed to take a bit more heavy use/abuse over time.
Just thoughts.
Butcher
02-20-2005 11:03:49
Your gonna like that 401. Weve got a 401AD at the shop. It is almost bullet proof. It takes alot of abuse from the help. I think the loader weighs more than the tractor. Just wish it had rear remotes.
Mark - IN.
02-20-2005 06:42:57
Yesterday on my way in to town, I observed the same things that I usually notice on weekends when I'm home. There's the same Case 5xx setting out by the road at the asphalt place not far from me where it's been setting for a year, big bucket and backhoe. Would be nice for side income. Then just past that is the guy with a nice '60's or '70's Deere, can't make it out, but looks to be a 4xxx, with a loader, setting out next to the barn where it hasn't moved all winter, but is a nice looking tractor from what I saw. Would be nice to have too. Then I had to stop and wait for a guy that was backing a Case industrial (same or similar to the asphalt place, think 580?) out across the road carrying HUGE bolders from one end of his yard to the other. Yep, certainly would be nice. After seeing the HUGE bolder in the bucket, I took a good look at the bucket mounting and was far different and beefier than anything I have, or you see on AG tractors, and that industrial was shorter and sits lower than AG's do, and I'll bet those front axles are larger and beefier than AG's are. I jut coudn't envision AG's with loaders lifting too many of those boulders, and not for long.
Then I continued on my way into town to the bank. On my way home, ran past the Deere dealer just over the Michigan line in Union, and looked over that 4520 deisel that's been sitting up by the road. Front and rears are about 20% at best and one of the rears is flat. No biggie that the top link and guards for the swing arms are missing, no biggie. Has 6100 Hrs and needs a few things, no biggie. But has a brand spanking new battery and new cables, which tells me that it'll fire right up, and the dearler is gonna want $$$ for it. They were closed, and I'll call later in the week. I'm sure $$$, but it's all original, including the pea green oxidized paint. She's a beaut.
Sounds like you have a couple of nice tractors there, that get the job done, and that's what's important.
Mark
JiminIA
02-20-2005 05:51:41
We always used industrial loaders on my dads dairy. The loaders are built heavier.faster hyd cylce times. sometimes lower to the ground and wider. Generally just heavier and better suited for loader/ backhoe and heavy abuse...Jim
JiminIA
02-20-2005 05:50:21
Fawteen
02-20-2005 04:22:33
Among other things, Industrial versions of farm tractors tend to be geared a mite faster (particularly in "road" gear), have heavier front ends, lack 3 point hitches and/or PTO's, and came with different tires.
barryinmn
02-20-2005 18:50:18
 Re: Industrial tractors in reply to Fawteen, 02-20-2005 04:22:33
Old Industrials do not have quik tach loaders, backhoe, takes bolts to remove radiator screens not clips.
Maintenance is more a pain but I would not trade for an ag equivalent!
