Tractor Talk Discussion Forum
hydraulic problems
Michael A
02-20-2005 19:49:17
I have a 1963 Fiat 411r which looses the hydraulics on the 3ptl after 20 minutes of operation. I have been told is either a problem with the 'buckets' in the rear hydraulic section under the seat or the pump. Any advice on where to start, what I should look for would be helpful as I am new to tractor repairs and the old girl hasn't been looked after.
Thanks, Michael A
J. Schwiebert
02-21-2005 06:19:20
 Re: hydraulic problems in reply to Michael A, 02-20-2005 19:49:17
A couple of questions. Do you have the valve to run a remote cylinder? Does it make any noises? Have you checked the strainer and what are you using for hydraulic fluid? Also when you say you loose it, be a litle more specific please, does it try to lift or what. Next do you have a shop manual. Where are you located? I can send you some pages via snail mail if needed.
